2008 LC Headlight Replacement Question
Boise, Idaho
I have a 2008 with 145k miles. The headlight assemblies are pretty ratty by now. I am contemplating ordering two new assemblies from Toyota. My question - will the new headlights be quite a bit brighter then the cloudy assemblies? Are they relatively easy to replace on the vehicle?
I plan on keeping this for a few more years ( bought in it 2017 with 65k miles on it). It seems like a worthwhile "upgrade".
Swapped out mine a few years back. The color is clearer but depending on how bad they are yes it'll be brighter since there's nothing disrupting the light.
Will require removing the bumper, or at minimum undoing the sides and pulling it off just a bit to get to some of the bolts for the assembly. Still a very easy job though.
I was very happy when I replaced my 2013 headlight buckets with new factory parts, even after they had been polished previously.
Whether you’ll notice more light will depend on how bad your current ones are, but if they are yellowed there will definitely be a difference.. mostly in the headlamp actually being able to put the light where it’s supposed to be on the road.
The new assemblies won’t come with new bulbs.. I’d recommend replacing those at the same time.
Changing the assemblies isn’t super difficult but does require removal of the bumper skin and grille. It helps a lot to have an extra pair of hands for the bumper, especially on reassembly.
What I would do- is buy a new set of later model (2013) HID headlamps and install- there's some wiring changes that would need to be done, but not too hard.
Did you guys put some sort of UV protection or film on the new headlamp assemblies when you installed them?
I don’t but probably should.
Kind of assumed they’d be really difficult to film due to the significant bulges.. but hadn’t really looked into it.
I found someone selling a pre-cut ppf kit they never used. If I were too do it again would definitely take to a ppf place to make the cut and fit perfect
One more thought..
On my original lamps for a while I did try applying a nice synthetic car wax, hoping the UV protection in it would prevent yellowing.. doesn't seem to have made a difference at all.
It'll be PPF for me in the future. Just need to pony up for it.
first set of oem lights lasted 19 years
replaced with oem lights again - good as new
Just a head up on the ppf. I had laminx on my wrx lights and it ruined them when it was time to replace. I used heat and a steamer on them and it still pulled the factory clear coat off the lens. Im not saying they all will do that but I wouldn't use the laminx again.
Good I to.. thanks.
FWIW, when removing various parts to access the light assemblies be prepared to have many broken plastic clips and rivets. I have replaced lights on vehicles of similar age and those pieces are basically consumables.
I would usually agree but so far mine has been great about the plastic hardware surviving. Not sure if they used higher quality stuff on these cruisers or what..
