For Sale 2007 Toyota FJ Cruiser
Mississippi Gulf Coast
Year
2007
  1. FJ Cruiser
Mileage
222000
Color
Blue
Outside Link
https://www.facebook.com/marketplace/item/1117113159102737/
2007 FJ Cruiser $221,XXX miles, 4WD, rear locker (works), Voodoo Blue, ARB bull bar, 8000# Ramsey Winch with brand new synthetic line. Convenience package and the off road package #2. Running boards. Transmission does not, nor has it ever shuddered while I’ve owned it. Orange stuff in the undercarriage photos is the local orange clay, not rust.
$15k
The Good
  • Southern car, no rust
  • Clean Carfax
  • Hollandia 700 Sunroof
  • TRD Exhaust
  • TRD Cold Air Intake
  • Rear locker works. We make a point to engage it about once a month.
  • CV boots are good
  • Inners repacked/rebooted by me at 208791 miles
  • Outers repacked/rebooted by PO
  • Both rear bearings have been replaced at 211023 miles with OEM Toyota
  • Both rear axles seals replaced at 211023 miles with OEM Toyota
  • New Powerstop rear rotors and pads at 211023 miles
  • Replaced both rear parking brake shoes at 211023 miles
  • Rebuilt both rear brake calipers at 211023 miles
  • Front Diff fluid changed at 208442 miles
  • Rear Diff Fluid changed at 211023 miles
  • Transfer case fluid changed at 208442 miles
  • Transmission flush performed at dealer at miles
  • New hood struts
  • Replaced cabin air filter at 208360 miles
  • New OEM Toyota lower oil pan at 213638 miles
  • Oil pickup screen cleaned at 213638 miles
  • New rear Rancho shocks at 211023 miles
  • New front coilovers (shocks & coil springs) (Dobinson) at 218752 miles
  • New sway bar links at 218752 miles
  • Spark plugs replaced at 208442 miles
  • Rear axle breather extended
  • New OEM Toyota thermostat at 220547 miles
  • New OEM Toyota radiator cap at 220547 miles
  • New OEM Toyota PCV valve at 221438 miles
  • New OEM Toyota Evap Canister at 216124 miles
  • MAF cleaned and new o-ring at 216124 miles
  • Throttle body cleaned at 219308 miles
  • New OEM Toyota Fuel Filler Neck at 219435 miles
  • New OEM Toyota vapor Purge Valve at 221438 miles
  • New vapor purge valve hose.
  • New OEM Toyota exterior door handles
  • New OEM Toyota Interior Door handles
  • New blend door actuator at miles
  • New seals on the sunroof at 220547 miles
  • Sunroof drains cleared at miles
  • New ARB marker lights in the ARB bull bar
  • Blackstone Oil Analysis indicates normal engine wear for the miles
  • Has optional rubber mat in cargo area
  • Last oil change conducted at 219,139 miles
  • All axle zerks greased at every oil change while I’ve owned the car
  • 3 keys
The Bad
  • Code P0456 (very small emissions leak) is turning on the CEL
  • Subwoofer does not work
  • Keyfob does not work
  • Minor Rear Main Seal leak
