2007 LX470.
Hey guys I've been trying to troubleshoot a very difficult problem and I can't resolve it. The other day I got a check engine light and traction control light pop on and I hooked up techstream and got the error code p0335 which is for a crankshaft position sensor. Keep in mind the truck is running fine and there are no misfires or any symptoms.
I ran over to Toyota and grabbed a brand new crankshaft position sensor and installed it. I've been cleared the codes and took the truck out for a drive and the code came right back with a check engine light.
So I removed the glove box and unplug the connector to the ECM where the crankshaft position sensor signal comes in. Turns out it's plug E6 and pins 20 and 21. I tested the resistance at that pinpoint on the plug and it read 1300 ohms. I tested the pins on the crankshaft position sensor and they tested 2300 ohms which is exactly in spec. I'm guessing at the ECM plug at read 1300 ohms because of the long wires running all the way to the sensor. Also the fact that I got a reading at the ECU plug tells me that the wires are not broken.
What in the world could be the problem? Truck is running fine with no symptoms but I can't clear this code and the check engine light keeps coming back on if I do clear it.
Here's a picture from the manual and a picture of my plug. Am I testing the wrong test points? The manual clearly says it is plug E6 and pin 20 and 21. Or is there something else that can be throwing this code? Also timing belt was changed 2000 miles ago and everything has been fine until today.
