2006 LX470
Silverton
You may want to mute, I used my Samsung Edge video editor and added some of the default music. Funny at first but gets old. Also quality stinks, not sure why it's different from the previous one.
Lastly some of AZ.
Didn't do a whole lot to prepare. Took it to CBT for new brakes and rotor resurface, front wheel bearing replace, and new spark plugs. Also
rigged some tie downs for the fridge (thanks to @LandCruiserPhil for the reminder of the tie down points). Cabin, air, and fuel filter.
Amazing time and can't wait to get back to the San Juan range.
Finally got the fuel filter installed today. No surprises, went smoothly. 161,503 miles.
Doing a little catch up. Not a lot done. Changed air filter and cabin filters before our trip. Replaced passenger side leaking CV boot clamp before leaving. Replaced driver side when we returned as it started to leak on the trip.
Total trip was over 3200 miles. Avg MPG was 15.294. Packed light enough to leave the cargo carrier at home, I'm sure that saved me quite a bit. Not a lot of pics this time.
Hit another mileage milestone. Missed the even 175k but happened the day before on the road.
Northern AZ
Jacob Lake
Montana skies.
North Dakota sunset.
Last two miles to my parents farm.
Big perk to living rural. Let my 11 yr old drive the last 1/4 mile down the driveway.
Route there...
Route back...
New Tstat and fan clutch install in hopes to easily correct the 100 from running hot. No such luck for it to be that easy for me though. Off to CBT to troubleshoot. Water pump maybe? Probably radiator. :bang: I am at 177,531 miles so I guess can't be too upset.
Made sure to order the gasket.
Super easy. I moved the intake equipment back which gave wide open access.
Ordered an Aisin of of Amazon for next day delivery. Part number is FCT-075. Will keep the other and change the fluid in it.
Catching the thread up. Stat and fan clutch didn't remedy overheating. End of July new Radiator from CBT. Great service as always.
A couple of weeks later replaced cats.
Just today replaced X2 Power 27F battery (under warranty). Batteries Plus tried to recharge, ended up being bad. They said it should have lasted longer than 2 1/2 years so I got a bad one from the start. With 5 year warranty now have 2 1/2 left on the new one. We'll see.
Replaced cheaper LED reverse bulbs with quality PFran version.
Updating. Tuesday rolled to this.
@JT4runner Love them. Such a quality item. I've had his in my 80 as well and tried a cheaper Amazon bulb for the 100, obviously not the same.
