Will call after work, trying to see what best option will be.
From what I have gathered:
Trim packer option - every 5mm lowers .2 -.3 mpa, however the compression curve would yield higher drops in mpa as we move along the coil rate curve. I believe that I could get near stock with 30mm packers.
Lc100 non-ahc spring - firmer than packers and much firmer than ahc stock. But, would, at worst bring me to around 5mpa and I can add more weight or raise further.
Best option - "tired" LC non-ahc springs should bring me to a near perfect spec.
I want to move fast on this so trim packers may be the way to go for the the time being.
