Hey all,
I've been searching and googling this all weekend, so if this is in any way obvious, I apologize, but...
I've blown some "fuse" in my 2003 LX470 that supplies +12v to the trailer battery lead on my factory 7-pin towing receptacle.
Background: I have a camping utility trailer that I have a Goal Zero Yeti 1250 in. I've run wires to the Anderson Power-Pole DC input for the Goal Zero Yeti from the trailer junction box so that it can recharge from the truck while I'm driving. The Yeti is capable, however, of drinking 30+ amps.
On a recent camping trip, the 12v+ lead gave up supplying voltage. None of the fuses in the engine bay box appear to be associated (nor are they blown). In the 98-2002 LX series, there was a TSB that spoke of a "hidden" fuse (depending on the year) that would pop if you asked for more than 30 amps. I can't find the fuse, nor can I find one in any of the places that the 98-2002 TSB mentions. The rest of th elighting functions still work, so I don't think I've damaged the little box (wherever it is) that runs the 7-pin trailer connector. It's interesting to me that the little black converter box isn't where it is shown in the 2002 (near the drivers side taillight inside the finder). I havent found it, and the wires go into the loom right under the truck.
I have run +12v to the back of the truck for the fridge, a sub, and a couple other things, and so I might just run a thicker 10ga wire down to the 7-pin trailer receptacle so that 30 amps is no longer going to risk burning the truck down (the wire is not especially thick... 14ga perhaps?... on the stock harness).
But I sure wish I knew where that fuse is.
