Hello mates!
I am having a very strange issue that I wanted to see if anyone had any experience with.
2003 Cruiser 270,000 miles, have had for about 2 years - has been remarkably solid. Despite some wobbles at the start (after-market alarm had to be pulled out, some non-start issues, etc.), it's been a picture of health. Baselined heater T's, have redone the timing belt, all the classics.
Much to my surprise, I have been having these phantom electrical issues for the last month. Note: battery is new and in good health.
- It "seems" like if I lock the car with the remote, it drains the battery slightly, needing a jump. But if I use the door button or the key to lock it - its totaly fine - weird. In an attempt to diagnose this, I pulled a bunch of fuses to check with a Multimeter.
NOW THE MYSTERY—When I was pulling the fuses, some blue wire was jammed into what seemed like 4-8 fuses on both the passenger and driver sides, which were then terminated together on each side. I have removed that as it seemed like it was possibly linked to the aftermarket security system that was removed 2 years ago.
Everything seems fine but now some fuses seem to stop working intermittantly i.e. Dash was suddenly not working, removed and repaced fuse (with the same fuse mind you) and it is back, but now wipers are out.
Is it possible that, at some point over its life, some of the fuses were wired together to circumvent some issue? Why would you do this, and how come it still works (mostly)?
IH8MUD BRAINS WHAT AM I MISSING?
