2002 LX470 Unlevel Frontend
Savannah, Ga
I’ve had the truck about 1.5 months now. Always level across the front (driver and passenger the same ride height). After a 600 mile trip from coastal Georgia to Asheville NC, back down through Blue Ridge, the front end is sitting about 1.125” low on the passenger side. No AHC fluid at the top or bottom of the shock. We did do some sharp curve driving on the trip obviously. Could that have thrown something out of wack? Kind of stumped.
High and low still functions as it should. Truck maintains the same pass/low condition through all settings.
I also do not have a cable to read pressures at the moment. Thanks, Jeff.
UPDATE:
After getting home from work today, I moved the height adjustment arm to see if it would make up the difference in height. I marked its original position and slid it up about .125”. No change, so I moved it all the way to the top of the allotted adjustment. No change. On this system, what does that tell me?
UPDATE:
It doesn't work that way. The torsion bars are used to make it level from side to side. The computer takes an average reading from each sensor and applies what is needed to the whole front end. The sensors should be set similarly from side to side.
Turn the low side torsion bar up and the high side torsion bar down equal amounts, drive, measure on a level surface and repeat until both sides are level. The sensor arms are used to adjust final ride height of the front end as a whole.
Once it is level then read your pressures and adjust the torsion bars as necessary (equally this time) to get your pressures in spec.
UPDATE:
It tells you that you have a lot of reading to do. Put aside 2 hrs and start here: The ABCs of AHC - How to Measure, Flush, and Adjust all in one place - https://forum.ih8mud.com/threads/the-abcs-of-ahc-how-to-measure-flush-and-adjust-all-in-one-place.1211999/
Then you will find out that adjusting one front height sensor all the way will do nothing to a left/right lean, but rather make the ahc system inop, and a few other tricks and solutions.
I appreciate the input. I will read and learn. The link and info is very helpful. Look forward to learning all about this rig.
You guys have any idea why the sudden change in height?
No idea. Level it back up and keep an eye on things. Might want to check where your torsion bar on that side meets the lower control arm, it's rare that they crack/break but it can happen.
