2002 Land Cruiser Brake Caliper and Hardware
Birmingham, Alabama
table error, reformating
Wanted to make things a bit easier for anyone else hunting parts numbers for specific parts.
Please confirm with your year, but this should be for 1998 to 2002
Diagram IDPart#
47781 (RH)47781601101
47782 (LH)47782601101
47781B90119085718
47730 (RH)47730600801
47750 (LH)47750600801
47710A90105121754
90201-1245290201124524
31478B31478300102
47547B47547600202
446504465602301
494504945600201
494704947601001
447904479600501
47748A (No. 2)90468120152
47748B90240060244
4774847748600614
4773147731600404
47732B47732600204
Please confirm with your year, diagram and chart derived from partsouq: Partsouq link for 2002 Toyota Land Cruiser
There is an omitted couple of parts in this diagram worth considering. They're technically part of the steering/knuckle assembly but they attach to the back of the brake disc cover. Once you've taken everything apart, this is one of those "while you're in there..." things, especially if you're replacing the brake disc cover. This is the seal for the rear of the bearing sandwich, and it keeps dirt out of the ABS sensor mechanism. Note that there is a metal framed seal AND a rubber gasket between the seal and the brake disc cover.
Thank you!
In a somewhat related note if you are regreasing your front wheel bearings, dont forget about the THIRD bearing, the needle bearing in the knuckle; these bearings seem to get ignored when people perform their wheel bearing service. They could even be the cause of nagging noises from the front end that remain even when you change your bearings.
You can service them in a at least two different ways;
The LandCruiserPhil Spindle Bushing Greasing Method
or
via tool (SLEE or Homemade- Video / Forum Post) (seems in stock at Cruiserparts)
Greasing front spindle bushing – UZJ100
Careful with the DIY one's video, he ended up using the wrong grease (calls it out in the post, he used moly grease on the bearing)
Don't have any extra cash to toss, so will see how the homemade one turns out.
It appears pretty straight forward, and I will be doing a servicing on mine with the other bearings when I get time in the next few weeks.
If the seal is torn, or the bearing is completely shot, here are the parts:
43211V (RH/LH) - 9031672001 - SEAL, OIL (FOR FRONT AXLE HUB INNER),RH/LH
43211W (RH) / 43212M (LH) - 9038135001 - BUSH (FOR STEERING KNUCKLE),RH/LH
90364-33011 - 9036433011 - BEARING, NEEDLE
FRONT AXLE ARM & STEERING KNUCKLE
