2001 tundra
Pequot Lakes MN
what is the largest size BFG's I can put on my stock Tundra without Rubbing??? How difficult is the Tundra to put a lift in??
Stock size without rubbing and no lift. An easy (and inexpensive) lift for the Tundras are spacer kits that give you about 2 1/2" of lift and you can get 285/75/16 with little or no rubbing depending on your wheel choice. If you want full suspension, there are several to choose from....good, bad, and ugly...depending on what you are trying to achieve. As far as a simple spacer kit, figure on about $150 in parts, and 2-3 hrs depending on your tools and skills.
