SOLD 2000 Toyota Land Cruiser UZJ100 // 164K Miles // Desert Dune Metallic // Tan interior // Baselined // St. Petersburg, FL.
TampaCruisers
Supporting Vendor
GOLD Star
Tampa, Fl.
Year
2000
  1. 100 Series
Mileage
164750
Mud Fam', selling for one of our customers.
Highlights:
  • 2000 Toyota Land Cruiser, 164k miles. 2 owner vehicle, Florida Cruiser since late 1999.
  • Refinished in and out in Desert Dune Metallic (Base Coat // Clear Coat, door jambs, rear gate and underneath hood) (~2020); originally a Champagne / Warm Silver Metallic vehicle. Removed side claddings and color matched bumpers.
  • Tan / Brown interior; front seats bolsters were replaced with new OEM units and reupholstered the front and second row (~2020).
  • Sumo 10% Underdrive gear set.
  • 2" Dobinsons lift kit; Torsion bars, 4x shocks, rear springs, diff drop. (~2020).
  • TRD PRO Wheels w/ LT275/65R18 Nitto Ridge Grapplers (8-9/32 thread wear, DOT 2520). Matching spare.
  • Dobinsons Rear Drawer System.
  • Prinsu Roof Rack.
  • Slee Step Rock Sliders color matched with body color in Desert Dune Metallic.
  • Alpine Double Din w/ Apple CarPlay, hands free microphone with matching rear-view camera and speakers.
  • LED Bulbs throughout vehicle. In & Out.
  • Land Cruiser Grilles Grille with headlamp buckets converted to round headlamps. Light output is at least 50% better than stock.
  • ORS Dash Accessory Mount panel with 2 1'' Ram balls & phone holder.
Maintenance:
-She is baselined, and most preventive maintenance been handled already.
-Replaced mid-late 2024 (157-162k miles), OEM parts unless explained otherwise.​
  • Engine Oil, Diffs +Transfer Oil (new plugs), Power steering fluid, brake fluid flushed, Engine + Air + Cabin filters replaced.
  • Coolant System Overhauled, OEM parts; Radiator to Heater T's, Rad Hoses, Thermostat, gaskets, seals, AISIN Blue fan clutch + Fan.
  • Ujoints.
  • Brake pads. Front and back.
  • 4x Denso O2 Sensors.
  • Vbelt.
  • Lower pressure PS Lines. Gates.
  • PCV + Lines.
  • Cruiser Teq Bearing kit w/ seals. RT + LT side.
  • Sway Bar Bushings. Front and back.
  • Upper Lower Ball Joints. 555.
  • Outer Tie Rod ends. 555.
  • OEM Reman CV Axles. OEM Seals.
  • Battery terminals w/ new OEM Fusible link.
  • Fuel Filter.
  • Oil + Gas caps.
  • Wiper blades. Bosch. Front and Rear.
  • AISIN Front doors windown motors + tracks.
  • AISIN Front doors locks. OEM rear upper gate lock actuator.
  • 3rd Brake lamp replaced.
-Previous maintenance records.​
  • Valve Cover gaskets + Plugs (2014, 114k miles).
  • AISIN TBelt kit w/ Fan Bracket (2015, 120k miles).
  • OEM Steering Rack (2020, 138k).
  • Yellow Top Optima battery (2021).
Miscellaneous:
  • AC is cold, Heat is hot. Drives great, tracks straight. Cruises at 75mph no problems, handles higher speeds with ease.
  • Rear gate black out emblems (late 2024).
  • Front OEM 60 series Radiator grille emblem (late 2024).
  • Ceramic coated in 2022. Body and glass.
  • Extra Weatherstripping thru all doors and door jambs (late 2024).
  • Hood + Rear gate struts replaced.
  • Carpet replaced in 2020.
  • Black WeatherTech liners in front + middle row.
  • Sunroof works, all glass works.
  • Antenna goes up and down. New motor in 2008.
  • Front Viper tint from Mud' tint guy. Windshield have ceramic tint, 70%.
Vehicle is located in Tampa / St Petersburg, Florida.
Plenty more pictures to share.
Any questions or extra information request, do not hesitate to let us know.
Open to PPI's, can assist in transport.
Clean Carfax, tons of Toyota history service records. Clean Title. Same owner since 2005.
Submitted to BAT.
Extras:
-We can accommodate, modify, add any part to the vehicle at interested buyer request.​
-Also, any needed extra maintenance that you wish to have completed, We can also complete prior pick up / transport.​
-Remove Slee Sliders, subtract $850 from asking.​
-Remove Prinsu Roof Rack, subtract $750 from asking.​
-Add TJM T17 Front bumper, extra $850.​
-Add Green General Manufacturing rear spare carrier, Driver side, extra $1300. (Includes plate relocator + LED plate lamp).​
-Decide to change back to original grille and headlamps. No price change, you only get one set of grille and headlamps. If you want both sets, extra $500.​
Thank you,
Manny @ Tampa Cruisers.
Couple of questions from DMs to clear things up here too.
- Comes with 2 keys; one w/ Yodateq case (black) and one non fob key.
- We do have all 3 undercarriage shields, removed to show undercarriage panorama, they're installed on the Cruiser now.
- Rear A/C Works flawlessly.
Thank you!
I’m interested. Tried sending you a DM but it was blocking it as spam. Please reach out to me. Thanks in advance.
PM’d.
Thank you.
What type of sound system? Amp/ power subs, aftermarket speakers? Beautiful build
Hey!
Good afternoon.
No A/M subs or amps; speakers are ran by double din unit.
Alpine Double din, Alpine speakers and Alpine rear view camera. Simple system sufficient for 95% of most user needs.
Thank you!
Took her out this weekend for the SAVE Expo.
She sits at 164k miles.
Deposit taken for the Cruiser.
Cruiser is SOLD and going to a Mud’ member home.
She also got a facelift !
Thanks y’all for the interest.
