2000 lc starter replaced. Broke a couple connectors.
Flooded timber of Arkansas
This plug (pic below) is on the passenger side and I forget what it was plugged into. Anybody know what it is? It broke!
Also I broke a knock sensor plug and can’t seem to find an oem part number for a 2000 model.
My plan is to order these plugs and learn how to depin and repin a connector in the mean time (if thats possible on these).
Probably one of these:
Starter Wire Housing block 90980-11400
Housing connector 90980-11166
For the future of the forum, here are parts I recommend changing when doing the starter:
Starter Motor 281005010084
Intake Gasket 1717150020
Starter Kit 2822650070
Injector o rings 90301-07024
28100-50070-84
28100-50101-84
Thanks.
I found a pic of the plug from the first post before i removed it. Also, see pic of number “11428” on the plug. Anybody know what that is or have a part number? Many thanks.
If you add prefix - 90980 to those connector numbers, that's usually the Toyota P/N. Makes it really easy to figure out the parts. There are some that don't have a number on the connector, but I've found that the majority do have numbers.
So for the one pictured it would be 90980-11428.
This pdf is good for difficult connectors..
You may want to specify what years model they are for.
Why starter kit with starter motor?
