Need a little help. I noticed the brake pedal in my ‘11 LC is a little soft and curious if anyone has the brake bleeding procedure for the 200 Series. I have a Motive bleeder, TechStream and have done countless brake jobs over the years but I understand that the process for the LC includes putting the ignition on to allow the pump to push the fluid through the system? So there is no pumping of the brakes - just constant break pedal pressure and you can bleed it? I know about bleeding the ABS via TechStream and plan to do that as well but just want to make sure I have the basis procedure down.
Thanks!
Thanks!
