2 Snorkel Install Questions
I am getting a little better and mining the archives, and have read several great photo essays on snorkel installations. It seems that most of the attention is on the proper placement of the holes on the fender, and from time to time it seems that folks have an issue with the A pillar holes being to close to the rubber windshield molding.
When it comes to front-to-back placement of the snorkel, there is a considerable margin for error when it comes to lining up the snorkel body with the components under the hood (especially with flexible rubber attachments). However, it would seem that the proper placement on the A-pillar has a very slim margin for error before you are to far forward and into the windshield gasket, or to far back.
There is absolutely no doubt that the fender holes need to be drilled first, But does anybody have any suggestions on how to double check the front-to-back fit on the A-pillar before the holes are drilled in the fender using the fender template?
Am I making to big a deal about the A-pillar alignment, have folks experienced variation on where those holes are located?
Second question (those first two count as one !). I see a great deal of attention spent on painting the inside of the holes that are drilled. Yet it seems that regardless of how well the snorkel is attached, it will collect mud, sand & grit between the snorkel body & the paint. Has anybody removed an old snorkel to find abrasion or rust? Has anybody used clear silicon caulk to seal the seam?
There should be a template included with the snorkel, follow it to exactly and you will be fine.
There are several excellent threads on the installation and George (http://george4wd.taskled.com/snorkel.html) has a write up with pictures on his website for the Safari snorkel.
I have seen silicone used to seal between a snorkel and the fender on many occasions. I have not bothered and have never taken my snorkel off just to see if there is dirt behind it.
Take your time and use the snorkel template. Measure twice (or fifty times) and cut once. You'll be fine if you're careful.
When I fitted mine I painted the inside of my holes. I didn't seal the snorkel to the guard with silicone when I first did it but when I had the guard of recently to do some panel repairs I decided to check underneath while it was off. The dirt and crud had started to scratch the paint from the vibrations. Not to mention the mud that dribbles out while you are washing your car:mad:. I have now glued it down with Sikaflex. It won't vibrate now and there is no chance of dirt getting in between.
I don't know what my sources where exactly but I read quite a bit before installing mine and I remember being told to use the template for the large hole only. So after marking the holes with the template I inserted pegs into the holes on the snorkel, coated the pegs with ink or paint so I could line it up and press it against the fender and leave marks where the holes should be. They were slightly off from the template. So after several more trials I ended up using the template for the large hole only. This was on the new style Safari. It worked perfectly. Maybe I got a little lucky.
I installed mine a couple of weeks ago. Absolutely trust the template for the large hole. I marked and drilled the other holes in the quarter panel from the template. The couple of holes by the antenna mast were a little off. Follow the suggestion of drilling the large hole and then line up the bolts on the panel as a double check of the template markings. You should then have no problems at all with those holes or the A piller. I did use touch up paint after deburring the holes drilled.
It's been said a thousand times - but TRUST THE TEMPLATE. It sounds like you've read the write up's done by Christo Slee, Jim Brantley and George Scolarro. The are all three great write ups!
