2 groove pulley
Dude, I don't quite understand the question.
Do you mean..."Do I need a 2 groove water pump pulley?"? (no, but you should)
Or; "Do I need a different water pump in order to mount a 2 groove pulley?" ? (no)
I think it will fit. Did you get the little spacer too?
There were indeed changes in the '76 water pump, but wasn't that just the additional water ports for the oil cooler? The pulley that won't fit would be from a clutch-style fan water pump, and I don't know exactly when those started...
If I remeber correectly the fan-clutch type came out in late 76 thus causing the major differences in the pump types.. I could be wrong though. My 76 does not have the fan-clutch type and has a dual pulley, I will tatry to take a pic tonight if that would help.
Mike
I just did this for my minitruck PS conversion...
Yes, you need the longer 2F water pump. My "F" waterpump was 1" too short. I just got a '76 "2F" water pump without the oil cooler ports. Everything mated up just fine. Well, after the "big 'ol nut" fandango :doh:
Jody.
http://cgi.aol.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7956980430&category=6763
http://cgi.aol.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7956981253&category=6763
Here are two on ebay, one is the earlier(no fan clutch) and the later for FC and 7 blade fan for the shorter WP.
I just run the 6 blade fan and no FC...just one more thing to break.
With the older you will need the fan spacer which is a factory part to align everything and keep the fan blade out of your belts.
GL
Ed
