So the idle on on my 94 has slowly been been getting lower and lower over the past couple of weeks. It would try to idle briefly around 800 and then slowly drop down to almost but not quite stalling. Digging into it today I pulled the intake boot and sure enough there were some tiny cracks on the bottom. Since the thing probably needed replacing anyway I figured I'd try to repair it.
Looking through some odds and ends I found some tire plug strips from a old repair kit and thought that if they could stay in a tire at 75 mph maybe they could survive on the intake boot.
I cleaned the boot really well and then took some sandpaper to the cracked area to give the plugs something to hold onto. Then
basically jammed the plugs into the accordion section of the boot where it was cracking, making sure they were seated all the way down to the cracks.
After the fix it's idling normally again and is much nicer to drive. This may not last very long but it was dirt cheap, confirms that the boot is bad and buys me some time to get a new one. It could also be a quick fix if a boot decided to go south in the middle of nowhere.
...Literally!
