1st gen gas leak / fuel pump bracket
PNW
It started with trying to take out the fuel pump so I could put a fitting on the plate for my aux gas tank to drain into the main tank. In the process of trying to take off the pressure flex line I quickly sprung a leak in the rust/cancer infested metal line on top of the tank (the one shooting off towards the lower left)
Initially I sealed the leak, so I could move the truck around, with some cotton gauze soaked with JB Kwik wrapped tight around the line.
From my research, Toyota wants ~$150 or so for just the fuel pump bracket so I figured I'd just fix it myself. I finished yanking the fuel pump out, took the pump off the bracket and let it all dry. I cut off the 14mm nut/fitting on the fuel tank side and drilled it out to 21/64" (just a hair bigger than 5/16") since it was previously brazed solid to the metal line. FYI, there is enough material on that fitting to drill it to 3/8" if you need the extra fuel flow, but unless you're heavily modified, there is no point to it. I cleaned off the last bit of metal line sticking out the top of the plate and drilled a 5/16" hole through the original hole. I picked up some 5/16" brake line (same as original line) and bent it to the same shape as the original, slid the 14mm onto the new line and made an inverted flare to seal against the original flex line. I very carefully made 2 small tacks from the plate to the new line to hold it in place (easy to burn through steel brake line) and sealed it all with some regular JB Weld. Originally the steel lines were sealed with brass to the plate, but I don't have an oxy-torch to do that. Before tacking the line to the plate, I reinstalled the fuel pump to make sure everything was lined up properly - the only thing holding the pump in place is the rubber hose from the metal line and a small rubber grommet on the bottom. This is the finished product
So there you have it, the proper $10 way to fix a leaking fuel pump line
I also drilled a hole and added my extra fitting for the aux gas tank with 3/8" line using the same proceedure
I got it all back together and started the truck, no leaks at the tank, but now I have a leak where the flex line attaches to the frame rail (probably did that while I was trying to get the flex line off) :lame: so next week I'm dropping the tank (might lift it 1 inch in the process :D) and replacing the whole damn line from tank to firewall using 5/16" line - the original line is a serious maze of twists and bends, so I'm thinking I'll just run and secure it on top of the frame rail for simplicity.
Ya, no offense but if I went to all that trouble to pull the tank down and fuss with that bracket, I wouldn't trust JB Weld to hold it for long. Gas leaks can be pretty dangerous.
Smear a good coat of grease on it, so rust can't creep under the JB Weld patch, starting a leak.
Harris 15 Silver solder will last a lifetime......get it at any hardware store. Use Mapp gas not propane.
Good to know, thanks :cheers:
Didn't have to drop the tank to get it out, on 1st gen 4runners there is an access panel under the rear seat you can remove.
JB Weld wasn't my first choice, but I really don't think there will be any issues. I went out this morning and checked, the tank is holding pressure. I welded a small brace to the pressure line (+ the line is tacked at the plate anyway) to keep the line from moving and stressing the JB Weld. I also ended up coating the top with POR-15 too, so I don't think rust will be much of an issue either.
