1KZTE start problem
Pakistan
My KZJ71 has 1KZTE.
The Engine starts but stops immediately. It does so 3-4 times then it starts & runs fine with no issue.
This is happening on cold start.
Help required.
My KZJ71 has 1KZTE.
Help required.
Check diesel filter - check that the fuel line is primed and does not have air in it.
Im not a glow plug person so have no idea if its a glow plug issue.
@Oldblue
I have a timer set at 20 sec for the glow plug. It is working fine. Also ambient temp here is ~ 30 deg C. So it is not cold but in fact hot.
I showed my rig to a Engine Mechanic, he said that the valves are sticking & the head needs to be re-furbished.
The engine has run 150K & I don't feel like having the head re-furbished. It is a sealed engine & runs fine. This issue has cropped up since last two weeks. My ride nowadays runs only a few km daily.
Any tip on having the valves cleaned/carbon removed without removing the head
