- Thread starter
- #41
@BennyG367 Yes, it will work on your 1hz. PM has been sent
Any more mate, PM sent.@Deniliquin PM sent
Got any at the moment? Searching high and low to no avail. Thanks in advance!@wesintl yes, i have two in stock. PM sent
My truck is '93 HZJ75. Any intel is greatly appreciated!I had a friend recently try to install a boost compensator on his 2001 HZJ73 and found that the throttle shaft was too short for the housing. @likethewheel what year is the truck you are putting this on?
Nice! Hope you’re right. Any idea if the two part numbers are I noted above are interchangeable though? I can’t find the first part number anywhere but I may have found the second one, fingers crossed….93 should be OK. I did this to two engines. One was a 1991 and the last one a 1992 HZJ80.
Some info here: HZ/HD Boost compensator question/confusion - https://forum.ih8mud.com/threads/hz-hd-boost-compensator-question-confusion.1128520/Nice! Hope you’re right. Any idea if the two part numbers are I noted above are interchangeable though? I can’t find the first part number anywhere but I may have found the second one, fingers crossed….
Great link. Thanks for the share!Some info here: HZ/HD Boost compensator question/confusion - https://forum.ih8mud.com/threads/hz-hd-boost-compensator-question-confusion.1128520/
22540-17550 – most common listed for 1HZ turbo installs. Hard to find aside from one member (akella) on mud. Shows as used for 90-98 HDJ80(no 81) and 98-2002 HDJ 100.
2254017260 – 2nd most common (though not common), Listed as Boost comp and Hydraulic valve. Shows as applicable for 90-95 HDJ 80 and 81. Seen one for sale used but not many other comments on the web aside from it being a supersede from 22540-73100.
225401C180 – 1HZ with EGR, (also listed for Forklift) but listed as compensator, and boost compensator depending on the catalog. Also, has been recommended on mud, but never followed up with peoples experiences. This part number appears on the newest of models which are still mechanical injection. I believe this is what the Safari turbo install instructions is referring to showing that you swap a vacuum port plug and line to “convert” it to a boost comp rather than just altitude/EGR function.
