Anyone have one they could post up? Looks pretty simple but I’d like to confirm it gets set up correctly. And it seems to be missing from my FSM.
Thanks!
Thanks!
The hose that goes to your 4x4 vac valves (the hose on your firewall) needs to be connected to your small fitting on the vacuum pump not the manifold. also keep in mind those vacuum switching valves also fail at times so you'll need to check them too.hi all looking for a bit of help here.
i have a 1989 fj62 with a 1hdt swap and an h55 with the original split case
i just had my engine and transmission rebuilt. the transfer case/4wd worked fine before but now it won’t engage. i can shift high to low so that’s not my issue. the 4wd button won’t engage the 4wd and won’t light up. i’ve traced the vacuum lines and i think they are correct but im not 100%. i can hear an electronic “click” when i push the button so assume it’s triggering properly but somewhere between there and the vacuum actuator is where the issue is.
i have good brakes so know im making vacuum
i had one vacuum line that was disconnected in the engine bay. when i plugged it back in nothing happened
it’s the one my finger is pointing toView attachment 4024166
now my one main question is this… with a turbo charged engine is manifold not pressurized as opposed to vacuum? so why would this vacuum line be connected to the manifold port? or am i missing something here? you can see in the photo this is where that line from the vacuum pump connects
so the hose connecting the one along the firewall and the one off the manifold to the fuel pump should be separated? the diagram above by beno suggests that the hose to the vsv is connected to the manifold but maybe i’m reading that wrong?The hose that goes to your 4x4 vac valves (the hose on your firewall) needs to be connected to your small fitting on the vacuum pump not the manifold. also keep in mind those vacuum switching valves also fail at times so you'll need to check them too.
yes. beno's diagram is for a hdj80 and those are not vsvs in the picture, they are pressure switches to tell the red and green "turbo" lights to come on the instrument cluster.so the hose connecting the one along the firewall and the one off the manifold to the fuel pump should be separated? the diagram above by beno suggests that the hose to the vsv is connected to the manifold but maybe i’m reading that wrong?
take a picture of the "small vaccum line" it should be right next to the vaccum pump where the brake booster hose connects. If it's clogged, un clog it. it's only like 1" long before it connections to the large brake booster fitting.well i have a report and a question. now that my boost line and vacuum line are disconnected the engine runs much more efficiently. i dont make as much black smoke when i take off and ive gained about 10% in mileage. pretty terrific
now i still am having troubles with the vacuum side. again my brakes are good and i get a good “woosh” of air if i take off my vacuum line at the brake booster. the small line seemed plugged so i just swapped it out. i’m getting almost no vacuum at all through it. there are no kinks in the line and air moves freely when i blow through it when its disconnected. i dont know how the internals of these pumps work but is it possible that its just a blocked port or is there a reason inside that im getting vacuum out of the large port and not the small one?
on the small line with the engine running i can pressurize the line and it very slowly leaks back to 0. this seems wrong as i dont think in should be able to pressurize a vacuum line
1 and 2 are correct. the turbo light switches are pressure based not vacuum.Reviving this thread with a related question.. I"m swapping a 1HDT into an FJ60.. From reading the repair manual and reviewing HDJ80 vacuum diagrams, it seems that the vacuum system is only needed for three things:
1) Brake booster
2) AC idle up (tho the diagram posted at the beginning of this thread doesnt actually show that)
3) turbo lights
Am I missing anything?
I'm considering running Torfab's new ibooster as well, which would mean that unless I want AC idle up, there would be no need for me to have a vacuum pump at all. Unless I'm missing something?
