1HDT revolution detector part number
Southern California
I have a 1991 land cruiser with a 1hdt. I just had the pump rebuilt and they accidentally broke the sensor and I'm having trouble finding it. Part number 83180-32020 based off of the year of my truck. I'm only finding 83180-60070. Can i use this part number instead? seems like the first one is for 90-92 and the other for 92+.
I'm not 100% sure, but if my memory serves me correct, the only difference between the two is an internal tab on the receiving end of the plug.
separate the pins from the plug and install your original plug and you are good to go. your 2 wires from the sensor and the green fuel cut-off should fit right into the plug
borrowed images;
you can make out the white tab in the 1st image
borrowed images;
I see! Thank you so much!
borrowed images;
does the sensor use a gasket or o-ring? Following the diagrams on Partsouq, it appears as if it does but would like to confirm.
