1hdft head on 1hdt block ???
Tin
Australia
Hi legends,
I have a blown up 1hdt (12 valves) cylinder head recently and about to order a new genuine one from Toyota. But Ive heard that its possible to put an FT head ( 24 valves) instead, just wonder if anyone else had done this before? If yes, what else do i need beside new injectors ?
Thanks y'all and stay safe....
Not 100% on the FT head on the 1HD-T, not really a whole heap of benefit in doing so unless you are going to be running 25+psi of boost. The FTE head works on the FT.
Hi legends,
May want to post in the diesel section to get the "right" group that is more knowledgeable.
Hi legends,
Hi,
Did you ever find out if that's possible? I am toying with the idea myself...
Thank you.
Roland
Hi,
Thank you.
Roland
I would suspect to get best result you'd need to do more than just the head.
Pistons, injectors, injector pump would all be specific to hd-ft
Piston bowl shape changed over the years to improve combustion.
Injector crack pressures are a lot higher in the hdft, the injection pump is different to deliver higher fuel pressures, and injection timing and fuel delivery is different too.
There'll be a bunch of small parts that are different too
Ok, i understand. Thank you for that info. It sure is a lot of change for all of 3 more HP or so. I was hoping for better air filling in the cylinder and better exhaust flushing after the combustion stroke.
I appreciate the info and your time, thank you very much!
Roland
Many differences from 12 valve to 24 valve beside the head.
You'd be better off selling the 1HD-T and swapping in a complete FT or FTE.
I like the way Toyota designs things. Not just a head but many more modifications.
Thank you Tony, i appreciate your input!
