What are the differences between the two and what trucks did they come in.
What are the differences between the two and what trucks did they come in.![]()
Apart from the 12/24 valve they had a fuel pump controlled by a computer(can be chipped)
I think the the 1HD FT came out in 96 or 97 in the 80 series and probably the Coaster.
did australia get the EGR too ?
What would I need to turbo the HZ in my truck? I was told to drop th e compression to turbo. Why? No other diesel engines need to do this are they weak? I would like to propane inject and water to air intercooler. If the exhaust temp starts climbing couldn't you use water injection?
I am planning to use a Garrett dual ball bearing turbo water/air inter cooler, can the exhaust be water jacketed too like on Mann diesels? What A/R on the turbo? .60 or .57? Where do you pull and return coolant and oil for turbo? So the weakest part of the HZ is the head? Is there an after market head avalable? How do you get extra fuel from the pump. I am more interested in using the HZ then the HD's.![]()
I don't think 1HZ head it's weak .. any one with bad experience on it . ?
I am looking at the GT 25 or 28 and external wastegate. I was told it is very prone to warping once turbo'd. I would like about 12-9 psi of boost and low exhaust temp. I am looking at what pump to use I think the stock one should be good enough. I would like around 200-250 HP. Keeping the EGT down is the key to turbo HZ from what I have found from reading various posts.![]()
As Dougal said only with a turbo un a IDI engine you can't reach 250 HP .. could be posible with intercooler 14 - 16 PSI propaine injection maybe ..
Did you read previous posts I am looking in the low A/R which means it will spool quicker lower the A/R.
I prefer the HZ one the higher compression and I all ready have it.![]()
