1FZFE engine overhaul
I recently disassembled the engine in my LX450. After hauling everything to the machine shop for cleaning valve grinding etc I noticed a small o-ring on the shop floor. Didn't remember taking it so thought it was for something else. Then I found an identical o-ring in the gasket set. The o-ring is about 3/8 to 7/16 OD by about 1/8 ID. Can anyone tell me where this goes? I inspected every part and don't see any recesses for an o-ring this size.
If you could post a picture of it sitting next to a quarter for size reference, that might help.
What gasket set did you buy? Toyota OEM?
It's a DNJ kit and by the way anyone wanting to rebuild a 1FZFE don't get this kit as it's missing a couple gaskets such as the oil cooler and thermostat housing gasket. I've been looking at pictures of other gaskets kits and while I'm sure the pictures could be missing some stuff none of them show that o-ring and I'm beginning to think the o-ring in question doesn't belong in this kit and it's probably something I tossed in there to get it out of my way. As they say neatness counts. :-(
Thanks to all of you that were contemplating this.
Don't think that OEM comes with oil cooler gasket either. Or that the head gasket is of the later/improved/non leaking design-with small round holes at the rear of #6 at the water jacket instead of the triangular holes.
You make a good point on the head gasket. I didn't know about the improved design but I think the gasket I installed had the triangular holes. Is it worth redoing with the improved gasket? The engine is still on the stand it'd just be the cost of the new gasket.
Or maybe the oil fill tube at the oil pan? But that wouldn't be 1/8 ID.
I was checking out your rebuild post. Awesome job. On the Cometic head gasket what thickness did you go with. I think while I have mine tore apart I ought to go with a better gasket than the DNJ thing.
