1FZ-FE Engine problem
Redmond, Oregon
I have a 94 FZJ80 and today the Engine decided that it will not turn over 2100 RPM's. The check engine light does not come on, the Engine just surges, Just like hitting a rev limiter. Any ideas on what is going on?
Just a total guess, but might be a crack in your rubber intake hose (the one from the MAF to the throttle body) allowing unmetered air flow in. That is, bypassing the MAF sensor. If you check and it is cracked, you can do a temp fix with duct tape until you find a good used one or buy a new one.
I looked the intake hoses over and they are good. As for a plugged cat I would exspect a loss of power. My problem is more like the ECM is shutting down the injectors until the engine rpm's drop to 1800 then they come on full throttle until the engine hits 2200 rpms and they shut off. If you hold your foot down on the skinny petal the loop just continues. thanks for the ideas keep them coming, we have until Saturday to dignose this problem, because Saturday morning I have a appointment for a dealer to look at it.
The check engine light does work. However it does not come on when the problem occures. Or I should say there are no codes being logged. I have the Toyota repair manual and the flash code list. When I checked there are no codes. :bang:
can you rev the engine past 2100 rpms in Neutral? Any change if you change the throttle at the throttle body?
Hah....the dealer? Good luck man they are just waiting for you to show up!
But for sure sounds like time for a scan tool at the minimum. And does run just fine up to 2,100? Like if you never needed to exceed that engine speed everything would be just fine driving around?
Like I said, if the engine is under 2100 rpm you would never know there is a problem. As for the Dealership in Bend Oregon they have a flat rate of $95.00 for diagnosis. Plus I have worked on the Allison transmission in there car hauler, So I have a little leverage. ha ....ha
hwy if you know a mecanic try to borrow some tools off of him. First I'd hook up a fuel pressure gauge, check the pressure at idle and then when its shutting off. Also some times you can have good pressure but not good flow. Check the filter. Next id hook a timing light up to the wires. See if the spark cuts out. then i would go with noid lights on the injectors see if thats cutting out. the igniton moduels on alot of us and domestic cars also control the fuel injectors. Aldata will have some good dioagnostic steps for you but it sounds like a fuel problem to me
Worked in many a dealer my friend...unless you really know peeps there you've got no in. And even in if you do you prolly don't. I'd find a good independent shop before you take it up the butt, I mean take it to the dealer.
And as for a fuel pressure issue? Why do people always think this? If the issue is so RPM specific it's has to be something else as fuel needs could be greatly exceeded at 1500 rpm at WOT then the fuel needed to be running the motor at say 2700 RPM as 1/8 throttle.
It's something else...and $95 for "check out time." I hate to rag on stealerships, but I would not expect much for that. Maybe a misdiagnosis at best.
Bringing this up as I am sitting in a parking lot 400 miles from home with this exact issue.
93, no DTC codes at all. The below video isn't mine, but its exactly what it's doing.
Often that issue is caused by the TPS or connection/related wiring failure. For some reason, the TPS connector isn't weather sealed, when water gets in there will cause this running behavior.
You are the second one to suggest tps after Gumby, it's dry but I'll see if I can get one from autozone
So this thread has been going on since 2009 with several 80 series having this identical issue "Revs to 2200 RPM and cuts out. " and I would imagine at least one of them was resolved.? My beloved 1994 was experiencing this exact issue and I'm sad to say had to be towed to the shop. First time in the 17 years 300k that I've owned it I was unable to field fix the problem and get back home under it's own power. Spent the evening and most of the morning researching the problem, gathering my test equipment and guess what.? it has miraculously healed it's self and left me with nothing to test. Of course no check engine light came on and no data was stored. It has run perfect for the last 100 miles. Sooo if anyone else out there has had this occur and actually did something to repair it, PLEASE share what your repair was as it would give me at least an idea of something to look at more closely before I get stranded somewhere out of coverage. Cheers.
