1FZ-FE Block issues?
Colorado
Website
cannabisforcolorado.com
Hey guys getting the head done on my LX450 and there is oil on the cylinder walls.
mechanic thinks it could be from lack of oils changes and or over heating. He things the rings could be getting suck and causing this issue.
Anyone else seen this? Only thing I can think of doing is spray a can of break cleaner down each cylinder and hope it breaks the crap up.
I picked up the truck with a blown tranny. It ran but ran like crap. Thought it was the head, also found the disturber cap was cracked.
Truck has been sitting for a while. Ill see if I can get some pics before the head goes back on.
Have you all seen the rings go bad? Truck only has 170,000 miles on it or so.
You can clean it off, but remember to put some oil on the cylinder walls before reassembly to prevent dry start damage. Engine parts need oil lubrication, including pistons, rings, etc.
Right I was planing on that. Just trying to get any gunk broke up before mounting the head.
Good news, all the valves are find and head is straight.
You can tell there's some polishing going on on the lower half of the cylinder wall. From these pictures does it look okay? It looks as though the cylinder walls may have gotten really hot
Like its burned
Wipe out the cylinders with a clean rag and take another pic.
I still see the cross-hatching.
I do not see any worn shiny areas .
I do not see any vertical scratches.
I see what could be ring blow by, but it could also be just oil dripping down the cylinder wall after removing the head.
Wipe it out and get good clean pics.
I see nothing there that would scare me, at least at first glance.
Right on fellas!
Thanks for your help!
