Is there a difference between the 1F and 2F carbs? It looks like they mount the same on the different intakes but I'm not sure if there is a difference between the actual carburetors themselves.
Note: This feature currently requires accessing the site using the built-in Safari browser.
There are a lot of changes both large and small to carbs from 1979 to 1979. Every year is slightly different. Check out the pictures on Specter off road web site.
Thanks, that helps a ton!It is possible to interchange carbs, but it is easiest to swap F carbs with other F carbs and 2F with 2F carbs because of air filter and throttle linkage differences that are not so easy to deal with.
I'll be running a D-40 single barrel carb on my '77. In hopes I'll gain better low end throttle response due to the larger throttle body. I've been running a cable actuator so the swap is a little easier.
The motor I bought is out of a 78, I don't really know anything about the motors themselves, I am just about to start my rebuild and I want to make sure I get it all right the first time. I appreciate the help.Depending on the year, some carbs were cable and some were mechanical actuated. Another difference is the single barrel carbs are mounted on two studs as opposed to 4 studs on the two barrel carbs.
