Parting Out 1999 100 series Land Cruiser
Marietta GA
I parted out a 1999 Land Cruiser a while back and kept these parts because I am a pack rat, trying to clean up the shop a little bit. The truck ran and drove great, had no check engine lights. It was bought at a dealer auction south of Atlanta and dismantled for the front clip and all associated parts pertaining to the airbags to fix another cruiser. The parts listed below are some of the special items that I saved from the project.
Brake booster / ABS unit $250.00
E-locked axle with actuator $650.00
Denso Alternator $75.00
Main fuse relay box $75.00
Sunroof motor $100.00
Front and rear driveshafts $50.00 each
8 coil packs with 100k on them $75.00
8 fuel injectors 220k on them $75.00
Two front doors $50.00 each
Windshield wiper motor $50.00
Throttle body with servo motor $150.00
All items were removed from a 1999 Land Cruiser with approximately 220k on it.
Thank you for looking,
Interested in coil packs if you'll ship to Canada USPS.
Sure, The ride might be expensive. Message me your address and I will find out the cost.
ABS unit has been sold
If it's Champagne Pearl code 1b1 I'd be interested in both outside mirrors if they still fold and are in good paint condition. Also you can sell the black knob shifter separate? The whole antenna assembly, rear view mirror {black trim} if it has the compass feature. And the black rear wind deflector.
Interested in the rear axle, what is the gear ratio? do you have the dash switch? I live in Gainesville about 1.5hrs away
Hi, do you have any of the following?
  1. Front brake lines (L&R) up to the pump
  2. Rear brake lines (without front to rear lines)
  3. Front speed sensors
All to 85048
Do you have the front driver door interior panel available?
