1998 Land Cruiser FSM & EWD are in the Resources section
Malleus
contact@Restore4x4.com
Supporting Vendor
Charlotte, NC
1998 Land Cruiser EWD (EWD383U), 339 pages, 7.8MB
1998 Land Cruiser FSM (RM615U), 1987 pages, 18.5MB
contents:
Introduction
Maintenance
General Maintenance (MA-1 to MA-11)
Equipment (PP-1 to PP-82)
Service Specifications (SS-1 to SS-51)
Diagnostics DI-1 to DI-684 )
Engine troubleshooting (DI-1 to DI-149)
Diagnostic trouble code chart (DI-14 to DI-18)
Parts location (DI-19)
Terminals of ECM (DI-20 to DI-22)
Problems symptom table (DI-23)
Automatic transmission troubleshooting (DI-149 to DI-216)
Diagnostic trouble code chart (DI-163)
Parts location (DI-164)
Terminals of ECM (DI-165)
Problems symptom table (DI-166 to DI-171)
Chapter 1: Electronic circuit matrix chart (DI-166 to DI-168)
Chapter 2: On-vehicle repair (DI-169 to DI-170)
Chapter 3: Off-vehicle repair (DI-171) [requires Unit Repair Manual A343F RM497U]
ABS troubleshooting (DI-217 to DI-305)
Power tilt/telescoping steering column troubleshooting (DI-306 to DI-339)
SRS troubleshooting (DI-340 to DI-439)
Wireless door lock control system troubleshooting (DI-440 to DI-472)
Theft deterrent system troubleshooting (DI-473 to DI-515)
Cruise control system troubleshooting (DI-516 to DI-538)
Engine immobilizer system troubleshooting (DI-539 to DI-560)
Body control system troubleshooting (DI-561 to DI-604)
Multiplex communication system (DI-605 to DI-617)
A/C system troubleshooting (DI-618 to DI-684)
Engine mechanical (EM-1 to EM-113)
Emission control system (EC-1 to EC-8)
SFI (SF-1 to SF-63)
Cooling (CO-1 to CO-19)
Lubrication (LU-1 to LU-22)
Ignition system (IN-1 to IN-13)
Starting (ST-1 to ST-18)
Charging (CH-1 to CH-20)
Automatic transmission (AT-1 to AT-33)
Transfer (TR-1 to TR-50)
Propeller shaft (PR-1 to PR-11)
Suspension and Axle (SA-1 to SA-185)
Troubleshooting (SA-1 to SA-2)
Tire and wheel (SA-3 to SA-4)
Front wheel alignment (SA-5 to SA-8)
Front axle hub (SA-9 to SA-15)
Front wheel hub bolt (SA-16)
Steering knuckle (SA-17 to SA-22)
Front driveshaft (SA-23 to SA-30)
Front differential side gear shaft oil seal (SA-31 to SA-32)
Front differential carrier (SA-33 to SA-56)
Front shock absorber (SA-57 to SA-61)
Front torsion bar spring (SA-62 to SA-65)
Front upper suspension arm (SA-66 to SA-70)
Front lower suspension arm (SA-71 to SA-76)
Front stabilizer bar (SA-77 to SA-79)
Rear axle shaft (SA-80 to SA-89)
Rear axle hub bolt (SA-90)
Rear differential front oil seal (SA-91 to SA-94)
Rear differential carrier (SA-95 to SA-113)
Rear differential carrier (with diff lock) (SA-114 to SA-135)
Rear differential carrier (with LSD) (SA-136 to SA-159)
Differential locking system (SA-160 to SA-167)
Coil spring and rear shock absorber (SA-168 to SA-174)
Rear lateral control rod (SA-175 to SA-177)
Rear upper and lower control arm SA-178 to SA-180)
Rear stabilizer bar (SA-181 to SA-184)
Brake system (BR-1 to BR-57)
Steering system (ST-1 to ST-61)
SRS (RS-1 to RS-50)
Body electrical system (BE-1 to BE-153)
Body (BO-1 to BO-143)
A/C system (AC-1 to AC-98)
