I live in North liberty, which is just outside of Iowa city. And update on the 97, my antifreeze is the color of oatmeal. There is some residual oil mixed in there I believe. I’ll probably go ahead and switch out the head gasket along with the timing chain and guides. Probably the smart thing to do but not a job I wanted to tackle!!! I want to drive it not work on it!
@LS1FJ40 is just north of you in CR. I'm sorry......
On the color of the antifreeze:
That sounds like the typical red/green mix that turns to brown sludge. Mine had the real bad and ended up exploding a radiator because of it.
Flush, flush, flush, new TOYOTA radiator cap, make sure your heater cores are flushed also.
You can do the HG if you're there and want to do PM anyway....... up to you.
Definitely check the oil cooler sales and pressure test.
May as well do a compression test and all that before getting too carried away.
The HG on mine was done by the PO (thank God!) and they had the head rebuilt with new seals, the whole works, and mine uses NO oil between 7000 mile oil changes.
When you get it all sorted out, make sure you go to the same dealer as LS1FJ40 because he gets $35 oil changes for his. I can't even buy the parts to do that!
(BTW, I have a cousin that lives in North Liberty, but he doesn't drive a LC....)
I also use the following for Toyota parts:
Toyota Parts | Toyota Online Parts | Genuine Toyota Parts | Toyota Parts Online
Delivered to my door for less than I can drive 5 miles to the local dealership.
