1997 Landcruiser Fully Loaded
Chicago
I have the chance to get a 97' Landcruiser with every option including factory lockers with 140,000 miles for $10,000. It has zero rust and is mint inside and out. Is this a good deal? It seems to be but I want some advice from you professionals! :). I've got a 1993 Mr2 Turbo and want to move into the LC world. Help me out.
Also what problems should I look for? Someone told me head gaskets were a common failure point and I should do a compression check or other methods in testing the HG's condition. Also I heard something about weeping steering knuckles. Just things I heard. Let me know please.
Thanks,
Brian
Funny you say that, I just finished reading most of them. Didn't see much about head gasket failure. Huh. I've spent many many days reading on this forum already and am no sloutch on automotive knowledge but I'm sure there are people on this forum that can spout out what I need to know in a few simple lines. Thanks for the quick reply dude!
Brian
Use kbb.com to figure out what is fair. According to what I put in, not knowing all the specifics, values were as follows: Excellent = $11,750, Good = $10,805, and Fair = $9590, so it sounds like you're getting a good deal. Check for yourself though, because kbb.com takes into consideration several things I did not know from your post. Don't think the head gasket would be that hard, though I've never done one, but I know the weeping steering knuckle isn't that hard to fix, if there isn't too much resultant damage in the birfields from gear oil leaking into there and thinning out the grease. When I bought my '93 it had the left side weeping. I fixed it myself, it wasn't too bad. Sounds to me like something you should jump on...
HG failure.
You can look for traces of coolant between the head/block. The problem with this is that you really don't get a clear view of things down there (bring a flashlight). Plus more often than not, the factory coolant (red) was replaced with some green stuff which is harder to see. There is also the bubble test and compression test.
Other signs of HG problems would be overheating and signs that cooling components were replaced. The HG is just one of things you can't count on. You might just want to do it as a PM like some have done and not have to worry about it. Some have had no signs of problems and their HG blew. I'd still show interest even if there was a HG problem, but with a much lower price.
I think the major problems you may see in the future is the HG and axles, but don't overlook simple things like brakes and tires. The combination can run up to $2000.
Hi. You know, the truth of the matter is value is so totally relative. For example, now that I have had my LX450 for just over a year, now, I can't see voluntarily being without it. Thus, the current value to me is way more than the 13.5k I paid. I didn't know it at the time, though, so naturally I bargained for the lowest price I could get. I think my vehicle was well worth ...well you name it! What other vehicle, currently, is made like the 80?
Naturally, you should want the lowest price, but if you see the value is there, be prepared to go for it or walk away. Don't become emotional about it... UNTIL AFTER YOU HAVE MADE THE PURCHASE!!!
Regards.
I bought my '95 FJZ80 around three years ago for $11,000. It had 124xxx miles on it. No leather or lockers, but otherwise mint. The one problem was the HG, which if I had known that the milky consistency of the coolent provided a clue, I would have used to negotiate with, but didn't. Finally replaced the HG at 170xxx miles because I didn't want a huge failure at an inconvenient time. New tires cost $800 for Michilins, and new brakes and calipers were something else, but those, and the PHH, have been the only problems. Oh yea, one other: I have to turn down the air conditioning because it gets too cold. Yours sounds like a good deal. And, what the heck, they're easy to fix. :grinpimp: Ned
Thanks for the input guys, I appreciate it. Are these really that easy to work on or was that sarcasm? I don't trust KBB at all. They say my 1993 Mr2 turbo has basically no value because it is over 200,000 miles. My friends 1993.5 Supra Twin Turbo through KBB comes out at $11,000!!! I think it is innaccurate for the most part. Especially when it comes to import cars like the LC since they hold their value much better. I'm going to test drive it today. I'll let you know what I dind out.
Was the transmission changed in 1997? A one year only trans??? I'm also in the market for a FJ55 in original condition with minimal to no rust. If you guys run across any let me know please. I've been looking but a fine example is hard to come by and when they pop up the price is crazy. Budget is another $10,000 or less (preferably less). Thanks again.
Brian
I think location has a lot to do with the value/demand of an LC. If it has no rust then chances are good it is southwest vehicle. FYI, after at least 6 months of looking I purchased a meticulously cared for 97 40th anniversary with 130,000 miles, ARB, Slee wiring harness, BFG AT's, 7pin mod, Lockers, rebuilt birfs, and all maintenance records from Indiana for 11 grand about 2 years ago. It had a front end collision with the ARB on, and was repaired by Toyota. The frame and underside did have a little surface rust, but very minimal. If I was to purchase the same vehicle in Colorado, I would have paid probably 2K more due to demand.
Hope you find what your looking for.
Baumber
1993 hardtop turbo MR2? WOW! I'm looking for one!
But anyway, I'm also in the market for an 80 series. I've seen a couple out here but most of them are high miles and really well taken care of.
The head gasket issues is the ONLY thing that scares me away from the 80 series but a lot of people have not had any issues, so that's always encouraging.
Good luck!
Ask cruiser-poor about the relative value of an 80. I thought I would never sell my '94, but I did, in order to buy his '97. And then, once he realized what an enormous mistake he made, he bought another '97.
Once you have one in your possession and do some baselining, you will understand the allure of these vehicles.
Good luck!
Good luck finding a Factory 93' turbo hardtop. There is only about 11 in the US. You could find a 91 but even then it is hard. Your best bet is buying a N/A hardtop and doing a swap.
Well I'm leaving to test drive it and do some inspections. I'll let you guys know whats up! Thanks again.
Brian
Yup yup... I miss my mr2. I had it for about 7 years...
Anyway, good luck!
Brian
That's interesting because they (91-95 Turbo) are reasonably plentiful in Canada. But after '95 they disappeared, the the Spider (Mk III) was never officially available here.
I just bought my 97 sage 40th with front and rear lockers for 10,200 two months ago. It has 140k on it. I didn't think it was a screaming deal, but was sick and tired of looking and test driving cruisers.
Ok here is what I ended up getting.
1997 Landcruiser
114,000 miles
Fully loaded including Locking Diffs
MINT white exterior and tan leather interior (not a scratch anywhere, even the driver seat!)
Everything works 100%
1 owner
clear carfax
full service records (through toyota)
brush guard (damage multiplier)
kc lights
new tires
NO RUST (Texas Truck)
Female owned and driven since new
Lets just say I was estatic. I'm still in the market for one more. Possibly a lexus LX450 as well. This time I don't need lockers and I want under 100,000 miles for under $10,000. Oh yeah it must be a 95-97. Let me know what you find.
If anybody is interested in a trade+cash, I have a 1997 Ford F-150 XLT 4.6L V-8, 4x4, ext cab, short bed, step side, 5 speed manual trans, 122,000 miles, ect.. overall nice condition and runs perfect. It is true market valued at around $6500 in it's condition. I know most on here are not Ford guys but I figured it was worth a shot. I'd take less $$$ in a trade obviously.
Thanks,
Brian
1997 Landcruiser
114,000 miles
1 owner
clear carfax
kc lights
new tires
Thanks,
Brian
Nice.
