Replacing the thermostat and radiator are both pretty simple jobs that you would do anyway if you did end up needing a HG. I would do those now and see what happens. If it stops getting hot, you will know you had a problem with one of them. You could still send in a sample to Blackstone to see if there is any coolant in the oil, which will be a pretty good indicator of HG failure.
It could also be the fan clutch, but that is also not a hard thing to swap out. There are ways to test that but if the truck "roars" when you start it, the clutch is probably functioning at least somewhat normally.
