1997 fj80 bad acceleration problems
Minnesota
Hi guys, I’m new to this website and am looking for some insight on a problem I’m having with my 1997 TLC fj80. On any given day, the startup is fine. Idles good and revs very well in park and neutral. I’ll drive down my drive way and no problems, until about 2-3 minutes into driving. I’ll be accelerating and it will start going, but then it will begin getting sluggish. The RPMs will spike up to around 3k and drop down to about 1000 and it will continue bouncing off of 1000 up to about 1200-1300. As soon as I floor the pedal, I feel lag and then it launches all the way back up to 3 grand. As the RPMs drop back down a thump can be heard on the PS of the car. As soon as the car is put in park and turned off and back on, the problem will go away for about 15 seconds but then it happens all over again. Sorry for the long post and thanks for any help!
It sounds like a transmission problem. Do the surges or fluctuations come when it’s changing gears? I had a similar issue and it was bad solenoids in the transmission. The easy way to check is to unplug the solenoid wire it’s the plug on top of the transmission. Drive it shifting gears manually. If the rpms don’t act up it’s the solenoids. Is your overdrive on/off light flashing on the dash at anytime?
Voodu,
Doesn’t seem to happen during gear shifting. Gets through the gears like it normally would’ve. O/D light doesn’t flash at all either.
It’s possible your catalytic converters are stopped up. Can cause the lack of power as well as the surge. And might explain why it takes a few minutes of driving to show up and goes away briefly after you shut off. Any codes?
Nhall,
Havent been able to get it over to a place to run codes. Closest place with an obd scanner is about 20 minutes away. I’m planning on making some time for it and limping the truck over there. How would I go about cleaning out the converters as well?
Get a obdii scanner, its worth having. You likely have something going on and reading the code or pending codes will help everyone assist you.
Nhall,
There are threads on mud about cat deletes and opinions vary on whether or not it’s a good idea. Some replace the cat with a straight pipe. Others simply gut them out. Some will argue to replace them. But I would start with the code scanner.
Tools,
Can’t tell if CEL is on or not. Haven’t confirmed if the bulb under it is out or not so I’m going to have to make time to get the codes run just to be safe.
For a bulb check, When you turn the key to start but not run the CEL should illuminate then go off when you start the car.
O'Reilly's will check your codes for you for free. So will most other aftermarket parts stores.
If you are buying a reader, this one is handy, reads codes, but also provides real time info, like temp, etc.
I like my UltraGauge and it's on there 100% of the time. I can check and clear codes while I'm driving if needed.
It's about $100.
Hey all,
Just bought a code reader and I’m pulling 3 codes:
P0130: O2 sensor circuit malfunction (Bank 1 sensor 1)
P0141: O2 sensor heater circuit malfunction (Bank 1 sensor 2)
P0401: EGR flow insufficient
Thanks ahead for any insight
