Wanted 1997 Collectors Edition or Anniversary Edition
Doug RetroResto
GOLD Star
Year
1997
  1. 80 Series
Florida United States
Mileage
500000
If anyone has and would consider selling a no-rust, nice condition, all the way up to fully restored FZJ80 Collectors Edition or Anniversary Edition, please and me a DM or reply to this thread with a picture and let me know the price!
Looking for triple locker and rust free Toyota Land Cruiser FZJ80 Anniversary Edition or Collectors Edition.
Thanks so much!!
I’m reviewing a few and hoping to make my choice in the next couple weeks. Just purchased beautiful 60 series through this forum this week!!
I’ve seen this one on BaT when it was there and since. Could you share details of the restoration? All is was able to see is dry ice blasting, window trim and replacement piece by the brake booster. Details of condition, rust underneath (what had been pot-15 treated and what not, condition of frame and if deep rust on there prior to por-15, etc), pictures of restoration, etc would help me make a decision.
What do you think happened the first time when it was sold for $35,000? Did that buyer just not realize what condition it was in and seller at the time not disclose?
I realize it will need work and I plan on doing a large restoration, just want to know what level I’m getting into up front. Thanks!
There was no deep rust, por 15 or any restoration done.
All we needed to do was fix minor issues, return hacked repair jobs back to OEM, dry ice blast the entire underbody then light Eastwood rust encapsulator over the treated areas, 1 spray can was all that was needed. Most of the work was done by the last owners prior to 2022.
There isn't anything needed to do now, just drive and enjoy it.
This is the full part list
Parts we installed
2x 90467-43002 radiator hose clamps
4x 90466-41008 radiator hose clamps
1x 96711-24030 VSS oring
1x 90430-27001 oil level sender oring
1x 90464-00604 vacuum clamp
1x 75710-60021 door trim
1x 75720-60021 door trim
1x 75730-60020 door trim
1x 75740-60020 door trim
1x 75660-60020 door trim
1x 75670-60020 door trim
1x 87245-60480 inlet B hose
1x 87240-60170 water valve
1x 99556-30100 inlet A hose
87124-28030 clamps
90467-22003 clamps
90467-16002 clamps
Prior Ownership
1x 11213-66021 rocker cover gasket
1x 22271-66010 throttle body gasket
1x 90099-14118 oring
1x 00295-00103 FIPG black
1x 12204-35040 PCV valve
1x 48061-60050 lower bushing control arm
1x PHH hose
1x Gauge cluster light kit
1x magnetic diff plug kit
1x magnetic xfer case plug
1x belt kit
1x timing cover gasket set
1x 04112-66036 engine valve grind gasket kit
1x 90467-09014 clip
1x 90105-06221 bolt
1x 17801-66030 air filter
1x 90982-08264 fusible link
1x 16571-66030 radiator hose no. 1
1x 16572-66021 radiator hose no. 2
1x 16573-66010 radiator hose no. 3
1x 41991-60061 diff lock label
1x 58916-60010-E0 box bottom mat
1x 82670-60040 junction block assy
1x 04466-60020 disc brake pad kit
1x 04465-60230 disc brake pad kit
1x 12261-66021 vent hose
1x 12262-66021 vent hose
1x 82662-60050 relay block cover
1x 90480-18001 grommet
1x 90467-09014 clip
1x 90467-04017-E1 clip
1x 23300-69045 fuel filter
1x aisin radiator fan clutch
1x aisin water pump
1x aisin radiator fan blade
1x 221-9362 denso radiator
1x 15188-66020 oil pump gasket
1x 15785-66010 oil cooler gasket
1x 16119-66020 thermostat gasket
1x 16346-66020 thermostat gasket
3x 90099-14118 oring
1x 90311-52022 type t oil seal
2x 90467-14001 clip
2x 90467-20002 clip
1x 90916-03117 thermostat
1x 16304-66020 coolant outlet flange
2x 90080-10249 bolt
2x 91651-60850 bolt with washer
1x 15115-66020 oil pump cover
3x 82711-60210 wiring harness clamp
1x 84999-10420 bulb
4x PT07660-20002 black lug nuts
Greatly appreciate the quick response and all of the info. It’s amazing how bad some people can screw these up. Good on you for restoring to OEM and bringing her back!
Any FZJ80’s, collector’s edition or anniversary edition out there, rust free and in good condition someone might consider selling for the right price?? 🧐
