Engine rebuild notes from receipts
Some Engine Specifics in my Receipts
-Installed TRD Supercharger System Part # PTR29-60097 (No. D-425-7) (4/2010)
-OEM Center Diff Lock Switch (3/2009)
-PCV Valve (4/2011)
-New Spark Plugs (4/2011)
-New Spark Plug Wires (2/2009)
-New Rear Brake Rotors (2/2011)
-New Rear Brake Pads (2/2011)
-New Distributor Cap and Rotor Button (2/2009)
-Front Wheel Bearings repacked (2/2009)
-New Rotor Assembly, Distributor (2/2009)
-New Tie rod End (3/2010)
-Slee Slider Steps for both sides (3/2009)
-Timing Chain replace (6/2010)
-Gear Crankshaft (6/2010)
-Gear Camshaft (6/2010)
-Chain VibRation Damper (6/2010)
-Chain Te Slipper (6/2010)
-Replace Rod Bearings and new O-Rings (6/2010)
-Chain Tensioner Assembly (6/2010)
-New EGR Valve (4/2010)
-EGR Valve Vacuum (4/2010)
-Replaced Head Gasket Assembly, Head Machined per Valve Job (4/2010)
-New Gasket Thermostat (4/2010)
-New Timing Chain Gasket (4/2010)
-New Gasket (4/2010)
-Block Painted refinished and smoothed
-Honed Block (4/2010)
-Replaced Piston rings (4/2010)
-Replaced Headbolts and Sealed (4/2010)
-New Water Pump (4/2010)
-New Oil Filter (4/2010)
Receipts ballpark estimate come to around $10-$14,000 for rebuild and supercharger.
Service receipts for:
-Oil changes
-Transfer case service
-Transmission Service
-wheel rotations
-wheel bearing service
-Fuel System Cleanup
-Emergency Brake Service
-Tune Ups
-New Belts
-ETC.
These fixes were done on another cruiser. I posted they were done on my truck which is not true. I mixed up the posters on the engine rebuild thread. Thanks Mikeyt for catching this.
-Intake/Exhaust Manifold Aluminum Ceramic Coated (for cooling)
-Airbox was powdered black
