Hey fellas. I’m in need of some guidance with my alternator swap. I’ve read some threads and watched videos. I just need a little clarification on the lock bolt and the adjusting bolt. Does the adjusting bolt need to be removed completely? I can see that the lock bolt attaches to alternator. I’m assuming the lock bolt will need to come out completely in order to remove alternator. Eventually the pivot bolt will need to come out.
Is there an order as to which bolts are loosen first, second, and third? Adjusting, lock, or pivot?
Does order matter? Or is it just a matter of loosening all so the belts become loose.
Point me to a best vid or thread if you may.
Thanks fellas.
Thanks fellas.
