1996/1997 LX450 black body (202) wheel paint code
tejas
i'm checking my notes here and 202 black is my body color.
then i think i have UCA31 Dark Gray Metellic for one trim color and a 6M1 for some other trim color?
also does anyone know what i should use to repaint this scalloped area on the aluminum wheels? i have a spare that is off and i want to paint it before i mount something on it.
couldn't find anything here yet.
THANKS
UCA31 (96-97) Dark Gray Metallic paired with: 202, 6M1
UCA46 (96-97) Light Grayish Beige Metallic paired with: 045, 1B1, 4
As you've discovered the alloy wheel color (dished areas and grooves on the LX450) appears to be the same as the Graphite color of the bumpers.
The face of the wheels is of course only clear coated bare aluminum with a milled surface. There were some long discussions in the past on this topic.
I forget who's doing this but someone on the forum is reconditioning (milling, coating) our Alloy wheels, maybe they will chime in with what color they use?
FWIW 045 you listed above is the paint code for single stage white (body color).
thanks man.
sorry i went back and forth beteeen trying to make this specific to my 202 black LX and including info on the other LX's. it's confusing to me so i may have made it overall confusing.
i guess my truck is:
so the 202 is black paint for the body that i have.
then you are saying UCA31 is both my trim color AND my "wheel scallop" color?
if so did we all agree on a good place to find this paint?
or maybe this place is where i get it? they seem to have a touch up brush for like $20 i thought i could get for the trim but if its also the color for the wheel they seem to also have a spray can for $40?
i mean i put in year and model and it shows the trim options and i guess mine is the Dark Grey Metallic?
so UCA31 is what i need which is "verified" by that number being in my notes?? and i can get the rattle can since that's the wheel scallop color too?(!)
i wonder what the 6M1 is that is in my notes or where to get that (or if i need it)?
next question as you indicated is can i clean up the polished flush surfaces a bit on my own? or is that a lost cause?
