So i've been chasing issues with this truck since I bought it and as usual MUD was really helpful.
The truck is a stock 1994 fzj80 with roughly 235k miles had issues accelerating and I get round 7mpg ignition was bad when I bought it so everything was replaced (coil,Spark plugs , wires ,capand rotor).
Fuel filter is also new ,TPS readings are good, coolant sensor replaced but nothin changed much UNTIL I played with the VAF gear.
At first I leaned it out a little (3 cog) the problem was the same but a lot more present, so I turned it the other way , 3 cog richer than the original setting and the truck is running MUCH better. The thing I dont really get is how that reading richen up mixture. Does it change fuel pump voltage by the resistor ? change injector pulse or else ?
Because I know im not supposed to mess with that part so I wonder if my fuel pump is just not getting the voltage it should or if its going out.
I seriously begin to miss my 60.....
No check engine either, still feel very underpowered. I know it can push more as sometime it doe it !
