1994 Land Cruiser stuttering/missing
Hey all, I'm new to toyota and new to the forum, and I am having an issue with my fathers 1994 FZJ80 Land Cruiser with 1FZ engine with roughly 123k on it. I'm having a random/intermitent RPM drop/tick/missfire that doesnt have any real pattern, nor can I recognize a pattern as to the conditions that bring out the malfunction. The rpm's quickly drop off 200-400 RPM in a second, and quickly shoot back up to pre-held RPM, quite violently (all happens within a second, sometimes back to back). When cruising on the freeway (roughly 70 mph), thats when it feels the worst like all cylinders missfire at the same time, and then combust, jerking the engine components around. It definately doesnt feel good for the engine. Sometimes immediately at engine start-up (without touching the gas, or the trans) it'll do it, just sitting there. Im kinda stumped on this one. The plugs, wires, cap, and rotor are newly replaced, so i figure its either air or fuel. Instead of throwing money & parts & prayers at it, I was hoping someone might provide some suggestions or even their own similar experience to help resolve this problem. Any and all help/advice is appreciated, cheers!
Try reverse with some fuel pedal. If she runs fine in R then your wiring loom is cooked.
Either open up and repair or buy a new one.
What squash said.
It usually cooks near the Metal EGR tube. I have been able to wedge a short piece of heater hose in between the EGR tube and harness with some success to eliminate the misfire. This is only a temporary solution though as the vibrations and flex of chassis will allow the wedged heater hose to eventually move. The harness needs attention.
What squash said.
Did you ever fix this issue? I’m having exactly the same issue right now.
