For Sale 1994 FZJ80. 1x locked. VA
Richmond, VA
Year
1994
  1. 80 Series
Mileage
295000
Color
Green
I picked this up recently. The former owner died of Covid and the family did not want it anymore. This was my friends sister's husbands project. His son is a mechanic at a local Toyota dealership and the work done looks good. I have fine tuned the suspension after they installed the lift kit.
1994
Stock drivetrain with center diff lock switch added
OME J spring lift
OME steering stabalizer
Iron Man radius arm drop brackets
Iron Man sway bar drop brackets
Iron Man 30mm front spring spacer to level the truck better
New brake master cyl
New pads coss drilled rotors and calipers on all four corners
New fancy radio and speakers
Cloth seats in good shape
Blue fan clutch
All fluids look new
New 315 tires. 35"
New Badlands 12k winch and wireless remote
New heater valve
New peaky heater hose
Radiator new
Runs good
Frame solid and no rust
Body has small rust in rear rockers
New steering box and tie rods
New headlamps
new tail lamps in the box
new Cats and other parts of exhaust.
Cons: Rear mud flaps loose
Trans pan leaking fluid
Flat black paint/coating in spots
Ac blows hot
295k on it
Located in Richmond VA 23239
I will Continue to fine tune this as I get time.
Asking $8,000. Obo
Price drop to $8,000
new OE fender corners installed for front bumper.
PM'd you
Updates
Iron Man front adjustable pan hard installed
DeltaVS rear bracket installed.
Swapped rear J springs to Mediums
Front and rear bump stop drops installed
VA state inspection passed
Tightened trans pan
