1993 with differing outer CV lengths
Lander, WY
I just purchased a 93, completely stock, does have front and rear diff locks. My drivers side front lugnut cap came up missing yesterday and also the grease cap plug had been pushed off by the shaft, I took it into the mechanic, he replaced wheel bearings, and spent a lot of time on the phone trying to figure this one out. We came to find out that the one shaft is about 3/8" longer (drivers side). Toyota told this mechanic they should be the same length. $700 :crybaby: is what new shafts from Toyota would be. The mechanic thinks I can live with the shafts being different sizes and just get a larger grease cap. Has anyone else had a situation like this. I do have 232K and I'm a student living on loans, so as cheap as possible is how we are doing this one. Thanks for input. Newbie in Idaho
What Rick said. Basically, your mechanic simply needs to source a newer style drive plate (part the grease cup fits onto) from a 95+ model. They're cheap. The newer ones have longer splines and that pushes the grease cup out to handle the newer longer shaft someone fitted onto your car.
I'm assuming some other disaster (broken birf clip, etc) hasn't happened. If the shaft indeed protruded out enough to actually push the wheel's center cap off, then something else is amiss. In your situation, I'd get the new drive plate and see what happens. Tell your mechanic to be VERY careful not to overtighten the tiny nuts that hold the drive plate on (they have cone washers). The torque setting is quite low and a little research here will find it. Common error is to break the tiny studs overtightening. Also, be sure he puts grease in the axle tip splines where it meshes with the new drive plate. BTW, the deeper grease cup will also work, actually. You can run the older one you have with no problems.
DougM
Thanks
Do I need to get the new drive flange? I found a extra large dust cap at Checker and took my dremel to it. A little bit of silicone and hopefully it holds, It should atleast keep the dust out. You guys rock, thanks for the input, I am excited to own a cruiser at last, There aren't that many for sale in Idaho, let alone with Diff locks.
Yes, otherwise the stub axle will not be positioned correctly. There is a circlip that is installed on the end of the stub-axle/birfield. The flange is about $40, maybe less. Contact Cruiserdan and he will know exactly what you need if you explain the details.
-B-
