1993 climate control malfunction.
Pacifica CA
My 1993 FZJ80 has the “manual climate control” Well, the temperature slider isn’t actually “manual”. The slider knob doesn’t connect directly to the heater valve. I am experiencing and intermittent issue in that you move the slider and the cable at the heater valve sometimes doesn’t budge. I replaced the valve a year ago. Yes the cable housing is clamped properly. There is an intermittent “disconnect” somewhere between the slider and valve. Where to start? Rip open the dash and use a meter to check the controller module at the plug before I just start throwing cash at new electronics?
