1992 Parts availability ?
Depends on what part. Some are discontinued, some are still available.
There's several threads on here about discontinued parts, as well as substitute parts from other vehicles.
Also check out the classified ad on here if looking for specific parts.
Like mentioned, depends. It's kind of scary to read the parts discontinued threads, but I have had very few real world problems going through the engine and associated parts on my 93. I have ran in to a few things no longer stocked in the US, but most have been here in a week or so. Pistons took a month. I'm actually more surprised what IS still available OEM.
Jason
Hi Jason,
That's why i am scared to pull the trigger after reading the 80's and discontinued threads.
Thanks
I sealed up a shortblock, rebuilt a head and slapped a decent little desmogged 3fe together. Every single part i used was either used or aftermarket. I only ran into a couple issues, mainly the air flow meter that i broke when i took the screws out of it. I used one from a v6 camry and it runs pretty good. No oil leaks and most importantly, no burning of oil
there will be times you might get stuck when hunting for parts but it looks like we as a community are still able to make it happen. Sometimes you will have to do a weird hack like i did with the camry AFM or worst case you will have to wait for a local partout. There are people keeping cars on the road much older than ours, sometimes you just have to be a little creative.
I’d look for a 93-97. Longer run for the 1fzfe and more engine parts availability at least for now. Plus a vastly superior engine.
I have a couple parts rigs for my 91. You could, situation depending, find and keep a parts rig if you are that worried. Worst case, you can swap later model or substitute parts to keep it on the road, such as engine, trans etc.
I wouldn't be worried about parts availability yet, or even for the next few years. Aftermarket, oem, and enterprising individuals are keeping these rigs on the road.
I am not sure or convinced if this is a true statement.
I would rather have a 3fe. At least in my opinion, it is more reliable, require less maintenance, much cheaper, better interior, and potentially save you thousands of dollars in engine rebuild... :cool:
