1992 LC power issues
New zeland
After thorough search through forums I cannot see anywhere this issue.
I have had issues with the sunroof leaking past the window seal into the drivers footwell.( fixed with silicone after checking a thread on this forum)
I have diagnosed that the window relay had corroded and needs replacing as no window would work.
I placed two jumpers into the relay terminals to give me power to operate windows in the meen time.
ISSUE 1
After a short trip to work I went to start the vehicle and I couldnt. I went for a second attempt and it started. Now every time I try to start it I have to turn the key on and off once before it will start.
ISSUE 2
I now have no dash gauges including:
-tachometer
-voltmeter
-oil pressure
-water temperature.
I also have no power to the following:
-Center console fan
My radio is aftermarket and still goes but it makes static noises.
Solutions:
-I have tested the alternator and I have 13.2vdc when the vehicle is running.
-I have charged the batterys to eliminate the low battery power.
-i have checked the fuses inside and under the bonnet including the fuseable link.
- is it another relay issue? Which one is it?.
- is it a fusible link issue other than the one I tested?
-Is it an earth issue? , if I had a bad earth I'm assuming I wouldn't have a good charge on my batteries.
You have a long road ahead of you.
You're going to need the 3fe electrical wiring diagram and a test light / multimeter and start tracing out the power path to see where things went wrong.
Optimally a lot of water got into an area with quite a few connectors and corroded them. That could likely be fixed by simply cleaning them.
On the crummier side of the spectrum water hit a circuit board somewhere, and you'll need to replace parts.
ISSUE 1
ISSUE 2
-tachometer
-voltmeter
-oil pressure
-water temperature.
-Center console fan
Solutions:
Just to be sure, because of your screen name. What engine is in your vehicle?
ISSUE RESOLVED.
it was the fuse. I cant believe it but it was a zigzag 10a fuse, I pulled them one by one and found the culprit.
it was blown on the side close to the spade.
it must have happened when I was jumping the power relay in the footwell for my windows.
thank you.
