Build 1992 FJ80 Build- MBOGO 2
Lexington, KY
MBOGO2 Build Thread: (MBOGO is Cape Buffalo in Swahili)
This will take me a few posts to get up to date over the past 7 months.
I have loved Land Cruisers for a long time, and my intro to them was in Africa. I sell hunting and fishing trips around the world, and hunting Africa is my passion, so I have been exposed to a lot of LC’s in Africa, Australia, Asia, New Zealand and Europe over the years. Scheduled to do my 40th Safari in August. I bought a 2025 LC as a daily driver in April of last year, and I modded it a bit to make it functional to hunt out of, but I just hated to beat it up right off the bat as I plan to keep it indefinitely. So, I bought a 1992 FJ80 in November 2025 from a lady in Florida. It was her husband’s project beater. I got it cheap but knew it needed a lot of work inside and out. It was two tone silver/gray with quite a bit of oxidation. The hood had spacers, the front bumper was angled down on both corners, it had a number of leaks, ac was decent but not great, driver seat had a good sized tear, passenger side a small one but all back seats excellent, minimal surface rust on frame, but back bumper crossbar was really rusted at the bolt holes. It had a Prinsu roof rack and Cali Raised lightbar that I liked and would have added anyway, etc. It had hideous wheels and super aggressive tires. It probably wasn’t my smartest buy, but I always wanted an 80, the price was right, and my wife was all for it. She agreed I needed a “beater” to hunt out of, etc.
My son loves to work on vehicles and can do some things, and we planned to do what we could together, and then big stuff, we would have to take to a local 4x4 specialist, and now I have found a 50-year mechanic that specializes in old Toyotas who is just a jewel. I have a 2-3/10 knowledge of the 80, most of that learned from this forum, but am learning.
The main three problems to start with were a bad coolant leak, power steering pump leak and an oil leak. Like I said, probably not my smartest buy. I had a thorough inspection by Commonwealth 4x4, and started prioritizing things. We replaced a ton of hoses and vacuum lines, plugs, wires, dist. cap and rotor, I found a back bumper cross bar for sale, cleaned it up and had it welded on, cleaned up some wiring, bought some slightly used Goodyear 285/70/r17’s and steelies to start with.
We put in a new power steering pump, thermostat, fan clutch, added a snorkel, and it was running pretty good. I knew the oil leak was a rear main seal, but it was minor, and I was going to put it off and take care of other things first. Then my son and I went to change diff fluid, and it took a ton to fill it, like it was almost empty. Then the next morning, it had all run out my passenger side knuckle. My axle seal was shot, so I had the front axles, birfs, wheel bearings, etc. all redone, and then changed both diff fluids.
I ran it pretty hard during spring turkey scouting and season and probably put 2500 miles on it in 6 weeks. Things were good minus my oil leak which was getting worse.
After season, I got a coupon for 30% off a cheap Maaco paint job, so I decided to have it redone in NATO green. It’s pretty darn good for the price, but definitely not a super quality paint job.
My oil leak was getting really bad, to the point where it was getting embarrassing on the street in front of the house. I had to have that taken care of, so I just had my guy replace the rear main seal, he discovered a part broken off the torque converter that was going to cause some major trouble, so we replaced with one from Precision of New Hampton. I am going to pick it up in a couple of hours, and will update at that point. but below is where we stand as of now...
Below is a list of things I remember that we have done, in no certain order: I am sure I have forgotten a few things. some random pics
Power steering pump
thermostat
fan clutch
snorkel
Rebuilt front axles - birfs, wheel bearings etc. and changed diff fluids at 260k
engine side gasket /valve lifter gasket
cleaned idle control valve
replaced vacuum hoses - coolant hoses- etc.
Shift module replaced
Spark plugs and wires, distributor cap and rotor, coolant reservoir, vacuum hoses
OEM Radiator cap
tie rod ends
rear main seal and front pump seal replaced
new torque converter from Precision of New Hampton
new steering collar
Back window louver
Head unit w/wireless Carplay
steering wheel wooden with my custom logo
Front bumper brackets
Air Injection rail check valve replace
AC recharge
South Africa front license plate
Weathertech Back cargo mat
grab handles roof rack
repainted grille
replaced tint on back hatch and driver’s windows
Console cup holder
Reece hitch- removed, sanded, repainted w/bed liner
Rear bumper crossbar and new aluminum step
new horn
Fender flare trim gasket
Hood liner
Paint exterior
Hood hinges
Light bar wiring/switch
Floor mats
door bezels interior
Phone holder
Badging sides and rear
New Fob
dome lights replaced units and led bulbs
patched exhaust
new battery
pioneer backup cam
½ Molle panel rear window
Fire Extinguisher
Tires 285/70/r17 33” good year territory mt
Wheels -Rough country +0 offset with custom logo on caps
Picked up the truck today and he changed rear main seal, front pump seal, the new torque converter and filled up with LE monolec 1150 transmission fluid. I was afraid we were going to have to do a rear break overhaul, but he said the rears look great. The truck is running really good, no leaks at all (first time since I have owned it), seems to shift smoother, and I am hoping I can just drive it without any major work for a little while! My son and I are putting pads and rotors on the front in the next week or 10 days, and I bought some OEM shocks from a member here for a great price, I want to put on. There is a KY Toyota Land Cruiser annual ride weekend that I am going to for a day or two next month, so hope I am sorted for that.
Other issues I need to tackle are – 1) center diff lock light isn’t coming on and did when I bought it. I don’t know if the diff is not engaging, if it’s just a sensor, or if the light is just burned out. I know there are tests to see if the diff is locking and light just doesn’t work, and I plan on doing that soon. 2) replace back window regulators and motors. I have had the parts for a while, but it’s not been a priority. The windows will fall off the tracks sometimes when lowered. 3) need to get speakers working. I put in 2 front door speakers and a wireless carplay head unit, but those are the only speakers functioning. I want back door speakers as well at a minimum. 4) I may have a small exhaust leak, so want to get that checked for sure. I patched a couple pin holes but think I still may have a small leak.
I will be in Africa in August and am getting a set of Escape Gear seat covers to save the $250 shipping. I have their dash and shift console covers and back of seat organizer and love them.
I know there will always be a list to do, and I guess that’s part of owning an 80. After 7 months of ownership, I have sunk a bunch of money in it, but I love the old truck and am enjoying the journey. It will never be a show piece, but hope to get it really mechanically sound, do a few more fun things to it (like ARB front bumper), just have fun with a classic, and fix what comes next as it comes. A few more random photos from today...
So after picking up the truck post rear main seal - I confirmed I had no leaks after wiping off everything I could from top and under and leaving cardboard under the truck for 24 hours. Feels so good to be leak free!
So this morning I took a garden sprayer with a gallon of degreaser and went to work. Then used a brush where I could and pressure washer. I guess it’s as clean as I can get it without a lift. This is sort of a milestone day to be leak free after 7 months of many leaks.
Very nice, i enjoyed looking at your build pics. I tell myself its the journey that counts, not the end…but my wife doesnt like that answer.
Mine wouldn’t either. I know this is a long journey but a fun one.
I put in an OME steering stabilizer. And found another small oil leak👎! From oil pan, so a gasket is ordered. Lasted 2 days dry…🙄
Habari Gani Bwana! Lived in Kenya for 20 years. Cruisers are what we drove. Did not hunt. Just did a ton of wildlife watching growing up. Love the paint job! Nice work! Tuta Onana rafiki!
After season, I got a coupon for 30% off a cheap Maaco paint job, so I decided to have it redone in NATO green. It’s pretty darn good for the price, but definitely not a super quality paint job.View attachment 4167862View attachment 4167863View attachment 4167864
Can you share what you did prior to sending it to Maaco? Did you remove anything? Or they did it all? Glass in? What package did you pick from their list of options? Thinking of doing this. Considering getting some fender flat gaskets for them to install. How long did it take?
I did their middle package because that is what was 30% off. I removed bumpers - wipers - cowl, and had them remove roof rack, snorkel and lightbar. Glass in and had them tape. There are a couple places with some paint on trim - they taped door handles and I need to do something about them. It took them about a week and a half but most of it was waiting on OEM gasket for fender flares which I had them replace. Otherwise they would have finished in 4 days. Feel free to message me about any details.
