1992 80 Pump Pulley
Hawaii
Hello all,
Ive been a huge follower of this page and absolutely love the feed back and tech solutions, helped me out a lot with all three of my LC's.. BUT IM STUMPED.....
On my 1992, Ive changed the pulley and key way 3x's, the pump seems to be in operable condition, Ive played around with belt tensions to a degree and still I have my PS pump pulley fail after about 200- 300 miles, the key way denigrates... Am I missing something ????? Ive only used parts that are OEM and still the same occurs. I guess I might be in disbelief the pump itself is gone (stock size tires) but this time I need the help..
Much Mahalo & Aloha
HI50LC
Can you post a pic of the shaft, key way and ID of the pulley. In most cases the key way is worn out on the shaft which lets the key walk around and trash the shaft and pulley. I see this a lot in my line of work but without pictures I cant tell you what steps to take. Could also be under torquing the nut. Check that PDF out and see if it helps.
UsedLuxury - Thanks for the quick reply..... give me a few and Ill send it.. Do you happen to know the tolerances (1/1000) if any I should be looking for on the "worn shaft / keyway?" I could see where your going if there is play, it could easily result in a shear..
With the shafts I deal with any play is no good. I can not say what is allowed on the PS pump on a lc. Does the woodruff key drop in or do you have to tap it in? If you are buying OEM pulleys I would hope the key way is in spec and you should have to at least tap the pulley on.
If the shaft keyway is worn, you can use Loctite 660 (black) on it. That product is specifically designed for preventing key backlash which leads to wear. I won't lock the pulley in place like a Loctite 260 (red) or something.
