1992 3FE Speedometer/Odometer not working (troubleshooting)
Princeville, HI
Website
www.raptorcorn.com
My speedometer/odometer are not working and I have been troubleshooting and have a question... If I have anything wrong, feel free to call me out, I'm pretty new to this stuff!
I am getting CEL code 42. I inspected the wire that goes from underneath the truck to the dash and it appears to be ok with no kinks (in the areas I could see).
Pic 1 shows where the cable meets underneath. I took the two little screws out to look at the inside of the 'electrical part' and it seems to look normal to me, but I'm not sure how to test this. I removed this whole unit via the 12mm nut and the gear inside looks good. When I spin the gear it spins the other end where the notched piece that fits on the wire goes.
Pic 2 shows the end of the cable where there is a metal piece that fits in the notch on the device in pic 1.
Pic 3 shows how the metal piece with the ridge disconnects from the wire that goes up to the dash. It seems to me like this metal piece should be connected in a way that it spins the wire. Both the end of the wire and the metal connector are round in the way they connect and I can't tell for sure, but when I spin the metal piece I can't tell if it is spinning the wire. Could this be the reason my speedometer/odometer are not working?
Pic 1
Pic 2
Pic 3
Did you ever fix your speedometer/odometer? I just replaced the housing and the sensor yesterday and no luck.
I replaced the whole cable from the dash to the VSS and it is working great! It was a super easy replacement.
Awesome! Would you happen to have a parts number for it handy?
Hi, Try pulling the cable out of the sleeve. Clean and oil it. Then replace it. Mike
Hmm. I’ll give the cleaning a shot. Definitely cleaned out the female end, but didn’t take it out of the sleeve. Some of the sleeve is looking brittle.
Just checked the ground wire too- if it’s the correct bolt on the back of the intake manifold that I’m looking at, it’s looks and feels like a solid connection.
