- Joined
- Aug 11, 2005
- Threads
- 21
- Messages
- 54
- Location
- United States
1991 Toyota LandCruiser FJ80 - $2300 KC
1991 Toyota Land Cruiser 236,000 $2300 obo.............
Leather (good shape), cold A/C, third row, tow hitch, tilt, factory push guard, rear heat, lock out hubs, key less entry, sunroof (needs seal….sealed shut so it won’t leak)
Added ASIN lockout hubs so you can remove front drive shaft and run in 2wd (I was able to achieve a high of 17.6 on hwy)
Has the newer Land Cruiser rims from 1993 (missing caps)
Runs and drives good (except slight shaking on hwy I believe because of alignment)….no rust!
Maintenance completed within the last 15k:
• Completed front axel rebuild with all new wheel and trunnion bearings/races and
new birfield joints. 1k
• Front calipers rebuilt/hard lines and rubber lines replaced (all factory Toyota) 1k
• Front rotors/brake pads 1k
• Brand new brake master cylinder (Toyota) 1k
• Cap/rotor/plugs/plug wires/air cleaner
• Fuel pressure regulator (Toyota)
• seal for shifter boot (Toyota)
• seal for steering shaft through firewall (Toyota)
• power steering pump rebuilt
• thermostat (Toyota)
• air intake hose (Toyota)
• cleaned throttle body and IAC
• throttle position sensor (Toyota)
• valve cover gasket
• fuel pump sock (filter) in tank
Needs:
• alignment (causes vibration at highway speeds)
• hard to start sometimes when hot (always starts though)
• engine leaks a little oil
• starter needs rebuilt or replaced
• valves need adjusted
• needs tires soon
• wheel center caps
• speed sensor for cruise control
VEHICLE IS SOLD AS IS
Needs:
• needs tires soon
• wheel center caps
