- Joined
- Jul 1, 2011
- Threads
- 6
- Messages
- 39
I found a bunch of great tips from other users scattered around the forums about changing out a radiator but wanted to put together a thread with pictures for the (sometimes) hard to locate mounting bolts for removing the radiator.
I'm a weekend mechanic by necessity so forgive me if I get some of the terminology wrong and I am pretty new to LC's.
I did this without completely removing the fan shroud, you will just need a buddy to help pry the fan shroud towards the engine (without damaging it) when you actually pull the radiator up and out.
-Detach upper and lower radiator hoses and two tranny fluid hoses on bottom of radiator (make sure you have something to plug them to prevent fluid loss)
-Detach overflow tube on top of radiator.
-Detach fan shroud and push towards engine.
-Remove metal cover to the front of the radiator in order to access nuts on the back side of "flat head bolts"
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
-Remove battery and battery box
-The flat head bolts are about 5 inches down from the top of the radiator on either side, you will remove the nuts on the front side of these view-able once the metal cover is removed in the previous steps.
[/URL][/IMG]
-Remove vertical bolts that hold the "L" brackets to the vehicle. These "L" brackets need to be transferred to your new radiator.
Once all these bolts are removed you should be able to pull the radiator up and out. It doesn't come out super easy and you have to do some maneuvering to get the new one in but just put it back in reverse. Hope this helps.
