1991 brake hardware question
Southwestern AZ
I will be replacing my front brake pads soon on my '91. Regarding the brake hardware, the FSM only shows the metal spring goes between the pads and the thin spring holding in the two rods on the caliper. Looking at pictures of other folks brakes they have the metal clip but no spring on the pads. Was this an upgraded change? Or is this only for '93 and above? My current setup (installed by PO) includes both. Does it matter having one hardware on versus the other? I wouldn't think both should be on there. Below is a pic of mine.
Those springs attached to the pads don't belong and you need a new set of anti squeal shims. You should probably replace the slide pins as well for a few bucks. Although the FZJ80 used larger rotors and calipers, the physical setup is identical.
